Slab Fail Frame Doesn't Align
Notice the following:
1. Plan shows the laundry recessed area should align with the garage. Photo does not.
2. Misalignment caused the laundry bottom plates to float. Ie, not resting on the slab! Refer to 2 items circled in the bottom right of the photo.
3. One of the drainage pipes is on the normal level of the slab (circled yellow). However, the plan shows that this should be in the recessed area.
How do I go about this? Does the slab need to be redone? Or just filled in the laundry section (to support the bottom plates) and massaged in the powder room (to extend the recessed area) section?
Now he would need to extend footing over or you carpenters would need to adjust the framing.
Happens all the time! Wrong/not properly validated set out done by concreter probably.
Funny thing is I have footage of them pouring the concrete and the concreter was even measuring from the front of the house as to where to put it!
Also, looks like drain is in the wrong place, so more chance it was a concreter.
But he could clearly see the drain being in the wrong place? So what was wrong with him?
So may be framing is wrong (less probably though)? Can you measure yourself?
I think from the plans, the pipe for the toilet sink is to sit under the frame (frame then needs to be modified to allow access to pipe). You can see a circle/crosshair in the plans just behind the toilet sink which I would imagine is the drain pipe. In the photos, you can't see this one pipe because it is covered by the framing (which hasn't been cut to allow access to pipe). They should have cut this pipe and put the formwork over it - that would follow the plans when the form work is removed and the frame sits on top of the pipe
Good thing for you is that it will cause no issues.
It looks like the plumber got his set out right. The pipe in the powder room is the toilet so being at floor level is fine. The floor grades down from the toilet to the floor waste in the middle of the room so the tiler will be able to get the fall you need.
The floor outside the laundry and behind the linen will need to be patched but that's not the end of the world.
The grano worker has got his slab step down slightly out.
Thanks. Laundry is fine as long as they fill it with concrete (not ok if they just slip some material to fill in the bottom plate of the frame.
I was more worried about the fall in the toilet as it's a smaller area and the fall will be too much. Next thing I don't want is the tiles in the toilet to the hallway not being flush - which defeats the purpose of having a recess in the first place!
Builders I know take more care when they know home owner is knowledgeable and or has a knowledgeable inspector with him,word goes right down the line, they will put their better trades with the more likely fussy trouble maker and or knowledgeable owner,it's not too late to put them on notice via knowledge, knowledge is power.
Tried this today. Told my SS to let me know when framing is done so I can get an inspection done. Asked me why I wanted to do an inspection every step of the way. I said I'm only doing 2 inspections out of the 5 available from Housepect. I think I hit a nerve or something. I was only going to do a pre-lining inspection but seeing their competency, I decided to add another one just for peace of mind
8
This is 100% true. You can not hang anything on steel frames. very frustrating
8/05/2024
3
This is the best I have, as it is plastered internally now. I should add there is a steel post in the corner of the room between the window and the glass sliding door,…
15/01/2024
7
Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder.
