CCTV on a new built house
I am building a two-storey house and should I install CCTV with the builders? or is this cheaper to do it after handover?
The builder quoted $3373 for 4 cameras and 1 intercom (installed), not sure about the brand and the quality as I'm yet to get an answer from them about this.
Should I just tell the builders to initiate a point for "future" cameras and I can call a technician to do this CCTV installation?
How much does intalling cameras cost if I buy my own CCTV?
Thanks.
I was in the same situation six months back, turned down builders offer for around $3k and instead installed myself 2 stickups and 1 doorbell under $1k. No wires, and works like a charm. good thing is you can fit anywhere you like and change the location as well if you need. Everyone sells it, Bunnings, HN, JB-HiFi etc.
https://au-en.ring.com/
Just buy ring stickups and doorbell.
Ring is good for retro fit and if you don’t mind your images being sent to the cloud.
If you have access to run cables a hardwired solution with local storage is far better.
I myself have a UniFi system.
Do you need the provisions for the cables to install UniFi system? or is it a stick on like Ring?
[url=https://au-en.ring.com/:35exek0r]https://au-en.ring.com/[/url:35exek0r][/quote:35exek0r]
I myself have a UniFi system.[/quote:35exek0r]
Do you need the provisions for the cables to install UniFi system? or is it a stick on like Ring?[/quote:35exek0r]
UniFi you need to cable it. But that was my point if you have access to run cables then in my opinion it is the best way to go.
If you are running cat 6 cable for future cameras just make sure your on top of site supervisor to pull through soffits. I ran all my cables for 8 cameras, drew diagrams where to pull through and the chippies still forgot to pull through. So now I either have to cut a large hole in soffit to reach in and grab it, or unscrew and lift of the roof -either way is a PITA.
I asked the builder to install all the cat6 wiring for all 8 of my future cameras. Cost me 400. When I moved into the house electrician just hooked the cameras up. He said if the wiring wasn’t there would have been very hard and time consuming especially for cameras downstairs. Worth getting the builder to do the wiring and terminate into one point like the study etc
which builder was it/ Carlisle homes is charging me around 1k for 7 data points and some weather proof enclosures
21
Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented…
29/07/2023
We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some…
9/08/2023
1
Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry…
