Hi,
I am doing porcelain tiling to ground floor after handover. My builder is asking if the tiler is gluing the tiles or doing sand cement. I checked with few tiles and they say it depends on the slab. Does anyone has more information on this?
Regards
Staircase bottom step
Correct, it depends on your footings and slab
Has you builder indicated what's required and the Cost?
More info required
Here
Expansion joints- Tiles
OT Try searching homeone's Database for key works (text)
on the other hand Images and graphical solutions are difficult to search.
For that I recommend you take a quick look at my previously posted images,
Engineering Details,Simulations Data and proofs
for further info post back or send a PM
I have 1000's of certified Graphical Solutions in my database
Cheers
Chris
Hi Chris,
My builder is just asking if my tiler will glue the tiles straight to the concrete or will they lay the sand cement bed before laying the tiles. The builder said that they need this information for the staircase bottom/first step gap with the concrete.
Regards
Ish
Regards
Ish
They are not open risers. But normal stairs something like below image
Gluing is easier and cheaper but it depends on the quality of slab/footings
alternatively laying a sand cement base throughout may yield a better finish for highly glossed Tiles
Where you may notice levelling variances in the slab.
the concretor will need to make allowances 20-30mm
Your opions are
1. Butt up the tile to the riser
2.Screed the whole floor have the tile run under ie open tread
3.Use a quad trim to cover
Thanks for the photo as it helps others
hth
Chris
Thanks a lot Chris for the information.
Regards
Ish
Regards
Ish
3
It's a good plan and friction losses are low at low velocity. Positive displacement pumps used as header pumps are simple, reliable, have high lift and work well with…
