Thank you in advance
Backyard Drainage Issue Help!
Hi All, Built a new home in 2022 the backyard had some drainage issues with the backyard flooding, I got a plumber out and they installed 3 storm water drains and plumbed…
21/06/2023
10
It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils.
11/08/2023
Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right…
