Garage lights positioning
Just wondering if anyone can help us positioning the two fluorescent tube lights in the garage with one metre extension, would it be better to put lights parallel or perpendicular to the garage door as we don’t want blocking the lights behind the opened garage door. Any suggestions?
Thanks
DB
Depends what you do in the garage, If you want to see in the engine bay when you open the bonnet then place them forward, if you want for general use then one centered would be enough. with a 1m extended garage you may end up putting in a small bench so put one centered and the other forward perpendicular to the door.
Thanks for your suggestion Brett
So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus…
18/05/2024
Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no…
