NBN Connection Process
As part of my building contract there was an item for NBN prewiring where the builder has wired from a point outside the house to a central point, where a powerpoint is available. (an additional $600 or so). They say they have installed a lead in this point outside the house from the street.
At handover I was advised by the builder that I would just need to contact an ISP when to get the NBN connected when required. However when contacting ISPs the property is not registered on their system and the ISPs referred me to NBNCo. NBNCo confirmed they don't have the property registered and it was the responsibility of the builder to advise them when the lead in is installed.
When I contacted the builder they advised they had never done this and that the owner would organise everything with NBNCo. This is inconsistent with all information I can find on the NBN web site. In the end I submitted a new connection application on the NBN site, and as expected they are asking for a plan of the lead in which the builder has not yet supplied.
I am curious on whether others have experienced anything similar. I expected the builder would take care of all required notifications to NBNCo so am really surprised that a major SA project builder claims they never get involved in this process.
Any feedback would be appreciated.
If you use a decent ISP the process will be a lot easier.
I recommend Aussie Broadband, who I used after my KDR. I had a few issues with NBN and they organised everything. They are well regarded in the IT industry as having among the best support. You can sign up without a contract, so even if you use them to get connected and then change to someone else.
But their introductory offer is pretty good anyway - $60 for the first 6 months for 50/20
https://www.aussiebroadband.com.au/
It is interesting that the multiple staff from NBNCo advised that it was the builders responsibility to register the development and that I need to do before any ISP can connect me. The Homeowners and Builders Guide on the NBN web site (https://www.nbnco.com.au/content/dam/nb ... -guide.pdf) also states that "The nbn and your builder will work together to organise the installation of the relevant equipment inside and outside your new home." There is no reference for the homeowner needing to get involved and contact the NBN to register the development, only needing to contact service providers for connection when required.
Overall the NBN connectivity process seems ill defined and unclear causing confusion for everyone!
Overall the NBN connectivity process seems ill defined and unclear causing confusion for everyone![/quote:34fc3073]
Rawson did nothing for me other than the lead in. I am also with Aussie b and we had an issue because of the old house, but I can’t remember what the term was. Anyway Aussie essentially had to start our place a new but they co ordinated it. I hassled nbn via Facebook daily though. 😁
The builder might have to do something for new developments, I’m not sure, as I remember reading that you may have to pay $330 for this pleasure?
Hi all I'm currently building a duplex in Sydney and we need to do a new water connection to the second unit. The water main is on the other side of the road so we need…
1/06/2024
2
I had to do this 2 weeks ago. I'm in Melbourne. The water company was Ok if moved upto 600 mm sideways. Any more than that and they wanted $$. The water meter connects…
