What are you planning to fit to the gas point and where will it go? If you are looking to install a gas fireplace or the like, there are minimum clearances and you can't put furniture right up against them, so where are your couches going to be to watch TV?
Try to think about where furniture would be placed in each room - at the minimum I would add another powerpoint to the Master - either side of where a bed would go. The entry looks quite long so I would add at least another light, if not 2. I would definitely have a passage light(s) on a 2 or 3 way switch. If person in Bed 2 or 4 have to get up in the dark, how will they access the switch (or install sensors) to get to the toilet or bathroom? If you come into the house at night via front door or garage how will you move through the house - no one wants to have to walk back to the other end to turn off a light? Will you want table lamps? Somewhere to plug in a vacuum cleaner - either rechargable or corded? A charging place for Tech devices? A second fridge? Where will you do ironing?
Lights - what are you plans for the kitchen -
lightsover a bench surface is a good idea so you can see what you are doing without shadows being cast. The light in the meals should be centered over where a table would go if there is only one. Bed 2 and 4 also don't look centered. Your pantry has no light at all by the plans.
One thing I have learned is you never have enough powerpoints.
