Could someone experienced tell me whether this toilet drain is OK?
As far as I can see the drain is shifted from the hole in the slab. Is it alright?
Thanks
Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for…
Agreed. I just found out today the certifier has not given the final sign off.
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
