Level 1 Compaction Report - Melbourne SE - Burbank
Has anyone else experienced issues in obtaining a level 1 compaction report for their block from the developer/surveyor?
The surveyor for the land we purchased advised they didn't produce a compaction report because it didn't meet the minimum threshold to require a report.
On the other hand, Burbank are saying they need a compaction report for their engineers based on our soil report returning a P class site classification and that additional costs may be incurred if we can't provide a report.
Any ideas on what we can do here? Anyone else been in this situation before?
Our land is in Bentley Park Estate, Keysborough, Victoria.
Cheers,
Kevin
The builder advised us to sign the contract, before they will perform any engineering analysis on the lot for us. The risk is, it could cost more when they do their analysis. Our neighbour who is building with Arden nextdoor fixed their site costs at 22k. Ours was fixed to 17k.
Best case, I'm hoping that the site costs will not change or at worst, change a little bit.
Then take the worst soil test ie highest reactivity and lowest bearing pressure to different builders and get them to quote site costs and fix the costs.
Don't EVER sign a builders contract unless you know what is in your soil.
I am about sign a contract from known builder, can anyone please share their experiences or suggest what to consider before signing contract. It would be a great help.
Regards,
Sumit
Hi,
Regards,
Sumit
Regards,
Sumit
Hi,
Regards,
Sumit
Regards,
Sumit
Unless you got your own soil tests done first, you are crazy. Don't sign anything unless all the costs are known and fixed. Always get 3 quotes and stay within your budget. Otherwise there are heaps of threads here about all the inclusions you should get or not.
Thanks kindly for replying. In my quotation it's mentioned inclusions up to P class engineered waffle pod slab. Does this means irrespective of soil test results builder won't charge extra apart from what mentioned in quote.
Hi,
Regards,
Sumit
Regards,
Sumit
What determines the thickness of the slab is the reactivity of the soil eg E class slab will be thicker than H1/2 etc.
Soil tests are not that expensive, forewarned is fore armed. Don't be an uneducated fool.
So not all developers can provide the level 1 compaction report? I thought it's required. Sorry for being naive.
If you are planning putting your house footings on the fill, you would need proper compaction testing to be done (eg radioactive).
Hi All, Recently we have signed a contract with Burbank and we are not aware that they have just DORSET, SURREY, HAMPSHIRE, KENT, PILBARA and REDGUM bricks from PGH are…
18/07/2023
1
isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest…
2/08/2023
4
they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo…
