Frame or pre plaster inspections?
My thinking is in the frame stage no walls are straight anyways and no plumbing is done.. So maybe do the inspection when they have everything in the walls but also concerned as the insulation would be in and not sure how much the inspectors can see, access and inspect.
Please share your thoughts and experience.
Thanks in advance
If you leave the frame to be inspected until after services are installed, then those will need to be dismantled if the frame needs to be redone in any area.
Thanks Arcadelt! I didn't think about that one!
8
This is 100% true. You can not hang anything on steel frames. very frustrating
7/01/2024
3
You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and…
14/07/2023
3
Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or…
