2 storey house will possibly cause privacy issue
The side of this proposed house will have a balcony and all main living areas will be overlooking my side of the house, bedrooms and bathrooms etc.
Only really an issue for the bedrooms and bathrooms.My living spaces are on the other side of the house, subject to no neighbours due to corner block.
I am currently in the process of having my plans drawn up, I will be in contact with my builder tomorrow over this. I have received a council proposed development letter and viewed it today.
3m will be the proposed setback between both adjoining side walls. ( total of 6m) The other house as I can imagine it will be higher and therefore I suspect that from their deck they will look at, and over my roof, and possibly down over the standard height fence and into my bedroom.
Can anyone comment b4 seeing my builder tomorrow??
Thanks in advance.
Then the rest is up to your chosen window dressing in those rooms.
The overlloking area is taken from their balcony in a 9 meter arc starting at 45 degree line from one end to a 45 degree line from the tother if that makes sense. A fan shape.
Overlooking from their windows into your windows is not considered if they are offset by more than 1500mm.
We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some…
3/07/2023
3
Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the…
