Bricks to ground
This is my first home build and my first post.
I have recently engaged eden brae homes for a tender.
I asked if the concrete slab is visible. I was told there was a 100mm "gap" between the brickwork and the ground.
And this "gap" is normally filled in by the landscaper.
Is this right ? I would have thought the the brick work would have been done laid to the ground.
tony
It is normal practice to have the slab exposed and yes, your should concrete a path to cover up the exposed slab.
thank you ..
Dear fellow home builders,
tony
tony
Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m…
13/08/2023
Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has…
