landscape plan
We are planning to build at Jordan Spring East Stage -2, however, it looks like we will have to submit a landscape plan ourselves, does anyone know of a cheaper way to get this plan, I have looked at bluegumdesign.com.au .
Any ideas,
Best Regards,
Randhir Singh
Did my plan. Implemented my ideas. Very well done, great price and good turn around.
Hi guys,
Any ideas,
Best Regards,
Randhir Singh
Any ideas,
Best Regards,
Randhir Singh
Diy
We were quoted $800 for the landscape design by our builder, but hubby used some online software and did it- we just had to abide by guidelines of developer eg which plants are recommended, required distance from A to B, aize of concrete area v/s green area etc
Hi guys,
Any ideas,
Best Regards,
Randhir Singh
Any ideas,
Best Regards,
Randhir Singh
Diy
Do you know the name of the software used? We are also in the same position. I've looked at BlueGum Design too, however I'm not after anything extravagant. I think I'd be ok designing my own.
Hi guys,
Any ideas,
Best Regards,
Randhir Singh
Any ideas,
Best Regards,
Randhir Singh
Diy
thanks, we looked at DIY path, but the jordan spring design documents states
"A landscape plan is to be provided at 1:100 @ A3 by a qualified landscape designer/architect/horticulturist"
unless they consider us as qualified landscape designer.
Hi guys,
Any ideas,
Best Regards,
Randhir Singh
Any ideas,
Best Regards,
Randhir Singh
Diy
Wow ok, then no DII've definitely heard that BlueGum is good though..
Hi guys,
Any ideas,
Best Regards,
Randhir Singh
Any ideas,
Best Regards,
Randhir Singh
Diy
I'll have to check with hubby n get back to you!
Diy
Thanks a ton..!
[quote="Spotme"]
Diy
Diy
Thanks a ton..![/quote]
It's smartdraw software
https://www.smartdraw.com/landscape-design/
Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney…
11/08/2023
Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right…
29/08/2023
2
Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help
