Building the Metricon Glendale 38 - Blackwood park Adelaide
Page 1 of 2
We almost pulled the pin due to Metricon changing random plans, however this was one persons error, which in turn almost pushed us away from their company completely. If it wasn't for Josh Clifford with Metricon I can assure you, we would have built with a private builder. If Josh is somehow on this site, thank you again for your dedication to your job, and clients. I can see that you really went out of your way to make things operate as smooth as possible.
Anyway, back to it. Me being a car nut, we chose to remove the ground floor study and turn it into a four car garage. Due to our land being on the high side, we had to split the garage with a 1200mm drop. We also widened the garage by 1200mm and made the rear of the garage a thoroughfare so we don't have to have side gates and to store more vehicles. We also have another split from the entrance hall into the lounge/kitchen area. I'm a huge fan of split levels, so I didn't mind paying extra for it. For our footings, competed cost was $69,000.00 and whilst it is very expensive, we are high up, will have a great view and always wanted to be on a Court. From the neighbours we have met on our Court, looks like its going to be family friendly which is awesome as all kids are around the same age, give or take a year or two.
Our SS seems friendly enough, however we are still waiting to meet him on site to discuss end dates and other little things. He has mentioned that the ground floor frame will be starting on the 17th of February (tomorrow) so fingers crossed.
Some dates to constantly update:
21st November 2016 - Land benched.
10th December 2016 - Land trenched.
16th January 2017 - Slab laid.
26th January 2017 - Water proofing strips.
2nd February 2017 - Electricity run to slab.
4th February 2017 - Fencing on site.
11th February 2017 - Steel support structure beams installed.
16th February 2017 - Starting retaining.
17th February 2017 - Starting ground floor first fix frames.
24th February 2017 - First floor frames and second storey sub floor complete.
2nd March 2017 - Second storey and roof trusses finished.
11th March 2017 - Piping and drainage completed throughout.
17th March 2017 - First floor gutters and roof sheeting completed.
22nd March 2017 - Brickwork begins.
3rd April 2017 - Windows and frames fitted.
19th April 2017 - Ground floor brickwork finished.
1st May 2017 - Brick work finished and electrical installed.
5th May 2017 - Flashing finished.
6th May 2017 - Cladding started.
3rd June 2017 - Cladding finished and eaves finished.
6th June 2017 - Cladding, eaves and piping painted.
18th June 2017 - Garage roof finished.
19th June 2017 - Insulation complete.
24-27th June 2017 - Gyprock installed.
5th July 2017 - Flushing begins.
10th July 2017 - Flushing finished.
13th July 2017 - Garage staircase installed.
14th July 2017 - Main staircase installed and rails installed.
15th July 2017 - Officially at lock-up - Wet areas proofed.
19th July 2017 - Second fix carpentry starts.
21st July 2017 - Vanities, kitchen cupboards installed.
25th July 2017 - Second fix carpentry finished.
26th July 2017 - Tiling begins in wet areas.
4th August 2017 - SMT drainage fitted storm water.
11th August 2017 - Stone benchtops installed.
13th August 2017 - Bermuda tile drains fitted and sinks installed.
18th August 2017 - front window Meranti feature finished.
19th August 2017 - Powder room timber plinth installed.
22nd August 2017 - Tiling finished, grout flushed and timber internal doors stained.
23rd Aug - 20th Sep 2017 - Painting and final paint touches.
25th August 2017 - built in robes installed and sink installed in powder room.
26th August 2017 - Balustrade on balcony fitted.
5th September 2017 - Feature walls painted.
6th September 2017 - Mirrors installed and second fix electrical begins.
8th September 2017 - Shower screens installed.
9th September 2017 - Timber balustrade internal stained.
13th September 2017 - Timber floor planks laid.
14th September 2017 - Rails in bathrooms installed.
15th September 2017 - Skirtings fitted to house throughout and pendant lights fitted.
16th September 2017 - Roller door and timber panel door fitted.
19th September 2017 - Walk through with site manager for flaws.
20th-26th September 2017 - Tradies fixing flaws.
27th September 2017 - Hand over day!
http://i1067.photobucket.com/albums/u434/acannell/re02_zpstw1ud6m5.jpg
http://i1067.photobucket.com/albums/u434/acannell/slab1_zpsrcd99ssm.jpg
http://i1067.photobucket.com/albums/u434/acannell/slab2_zpspidlmxk1.jpg
http://i1067.photobucket.com/albums/u434/acannell/slabwall_zpsghdr14sq.jpg
http://i1067.photobucket.com/albums/u434/acannell/slab3_zpsk46kdxiy.jpg
http://i1067.photobucket.com/albums/u434/acannell/beams3_zpsncythuis.jpg
http://i1067.photobucket.com/albums/u434/acannell/beam2_zpsfvavehez.jpg
http://i1067.photobucket.com/albums/u434/acannell/beams4_zps2ek1dttw.jpg
[url=<a]http://i1067.photobucket.com/albums/u434/acannell/frame-front_zpstlkbclte.jpg[/url]">
[url=<a]http://i1067.photobucket.com/albums/u434/acannell/frame-theatre_zpsslamsyvg.jpg[/url]">
[url=<a]http://i1067.photobucket.com/albums/u434/acannell/frame-garage_zpscspok3kn.jpg[/url]">
http://i1067.photobucket.com/albums/u434/acannell/frame-powder%20and%20laundry_zpsjdvvtjhr.jpg
http://i1067.photobucket.com/albums/u434/acannell/frame-lounge_zpsa3qkyvxe.jpg
http://i1067.photobucket.com/albums/u434/acannell/frame-kitchen%20and%20dining_zps2f8uxacv.jpg
http://i1067.photobucket.com/albums/u434/acannell/frame-butlers_zpsiydnbux6.jpg
http://i1067.photobucket.com/albums/u434/acannell/frame-rear_zpsmemly3qs.jpg
http://i1067.photobucket.com/albums/u434/acannell/front%20frame%20trusses_zpssl8nsepk.jpg
http://i1067.photobucket.com/albums/u434/acannell/frame%20-%202nd%20storey%20opening_zps3ffpouxj.jpg
http://i1067.photobucket.com/albums/u434/acannell/trusses_zpsff49e0k8.jpg
http://i1067.photobucket.com/albums/u434/acannell/2nd%20storey%20floor1_zps2kxqtsqo.jpg
http://i1067.photobucket.com/albums/u434/acannell/2nd%20storey%20floor2_zpsx88p7fre.jpg
http://i1067.photobucket.com/albums/u434/acannell/2nd%20storey%20floor3_zpsdxatiiv2.jpg
http://i1067.photobucket.com/albums/u434/acannell/windows%20and%20doors%20arrive_zpspbzznemo.jpg
http://i1067.photobucket.com/albums/u434/acannell/roof%20trusses%201_zps1iamdwd1.jpg
http://i1067.photobucket.com/albums/u434/acannell/roof%20trusses%203_zpsto4omjmz.jpg
http://i1067.photobucket.com/albums/u434/acannell/roof%20trusses%204_zpsuzsuk5vq.jpg
http://i1067.photobucket.com/albums/u434/acannell/dining%20windows_zpsf6gtsyvc.jpg
2400 high windows, very happy
http://i1067.photobucket.com/albums/u434/acannell/fishtank%20cutout_zpsd6djpvl4.jpg
Fishtank cutout underneath staircase facing the kitchen and lounge area.
http://i1067.photobucket.com/albums/u434/acannell/upstairs%20plumbing_zpsuwhl8ask.jpg
A view of the upstairs piping and drainage.
http://i1067.photobucket.com/albums/u434/acannell/hallway%20garage%20entrance_zps8mcsvzq7.jpg
Entrance into the garage from hallway. Bulkheaded with two cavity sliders.
http://i1067.photobucket.com/albums/u434/acannell/kitchen%20splashback_zpse174zo3n.jpg
Kitchen and butlers pantry splashbacks and piping.
http://i1067.photobucket.com/albums/u434/acannell/front%20door%20frame_zpsjyi6b7sr.jpg
Front door entrance and pillarless corner window (Isla facade).
http://i1067.photobucket.com/albums/u434/acannell/kitchen%20island%20piping_zpsjffgm14w.jpg
Kitchen island bench piping and drainage.
http://i1067.photobucket.com/albums/u434/acannell/backyard%20rear%20roof_zps8ul4nd8s.jpg
Backyard view of roof, ground floor trusses and whirly bird.
http://i1067.photobucket.com/albums/u434/acannell/upstairs_zpsesilpgye.jpg
1st floor roof complete.
http://i1067.photobucket.com/albums/u434/acannell/Garage%20bricking_zpsdueryvwf.jpg
http://i1067.photobucket.com/albums/u434/acannell/Front%20bricking_zpsgdflct3b.jpg
http://i1067.photobucket.com/albums/u434/acannell/garage%20bricking%202_zpsty2j5h4o.jpg
Gaslines have been run also. Here's our backyard BBQ/outdoor heater line that will be run underneath the backyard alfresco floor after handover.
http://i1067.photobucket.com/albums/u434/acannell/gasline%20backyard_zps3ku37tjd.jpg
http://i1067.photobucket.com/albums/u434/acannell/gasline%20side_zpsqefandno.jpg
http://i1067.photobucket.com/albums/u434/acannell/bricking%20side%20finished_zpsen6stctg.jpg
http://i1067.photobucket.com/albums/u434/acannell/front%20bricking%20pillars%202_zpsvrudvads.jpg
http://i1067.photobucket.com/albums/u434/acannell/front%20bricking%20pillars_zps0yu9qutg.jpg
Any chance we can have a look at your plans?
PS. you should add your build details into your signature, so more people can find your build.
I'll upload some plans of the house for you soon. I've just updated my signature, thanks for the info
Hi, sorry for the late reply. We've just our baby girl!
Congrats how exciting, new baby new beautiful home soon
Thanks very much. Pity the house seems to be progressing slowly now. We are around 2 months behind
Our eaves and cladding frame work are now completed. Our cladding should be finished on Tuesday. The main productivity has been my father and myself doing the rear retaining.
Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and…
13/12/2023
Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are…
