Help! 2-3m slope in land map. Site cost!!
We are looking into a 497sqm land in schofields. We took the plot map to 3 builders. One of the builder told me there is 2m slope (three wavey topography lines drawn on the map marked 42, 42.5, 43 and there is no unit next to this figures, doea ot mean meters?) and this will cost addional 20-30k extra in the site cost. This was masterton homes.
Fowler and wisdom homes told us the slopes are not an issue because the depth of the building will only be buildinh within 1 m slope, so would not involve much extra in the site cost.
Now the strange part is, we checked the land and it was prety evened out block! We couldnt even noticed any slope, not even .25m on naked eye! I called the land agent and the lady had no idea on the sloped/ elevations. Is it possible for a block of land to look even, and being considered to have 2-3 m slopes in it!!!
I wish i could attach the photo of the plan/ map here so that you guys could help me understand!
If you're unsure, I think you can get yourself a building site surveyor and they can do it for you.
Fall is very difficult to judge by eye until they cut your site. We have a metre on ours and it looks flat. The blocks in our estate that have 2-3 metres fall don't look flat however you would never guess that they have anywhere that much.
As you can see in the pic, you can see that there is a slight dip but the naked eye couldn't identify it as 2m.
We swapped it for a slightly larger block with only a 0.2drop, the difference in site/footings costs was only around 5k for us, the saving was made with fencing. Our quote for fencing and retaining walls was in the $16-18k mark but the almost flat block is less that quarter that cost. I'm not saying that it'll be the same in your case as I know there are several factors involved, I just wanted to tell you our experience
Not sure if you can really see it from that pic. My thread has heaps tho.
This forum has helped me a lot in understanding the hidden facts of buying a land and building on it in just 2 days. I had zero idea before thinking its just like buying a block of land, and get loan, choose a building design, get loan..... I was about to deposit for a piece of land last Sunday in Schofields. The agent supplied a map of plot showing many lines and signs. I asked her to explain the map and she said it was nothing special.... I did not deposit that day thinking I should read a bit and now I know there are no many facts to consider. Thanks God the lady gave me the contour map without me asking them. Otherwise I would've just deposited for the land...
needsausername & MJT: thats a very good idea, Thanks for the ideas
Marshall5858: no it definitely look anything closer to 2m, 2M would be close to the ceiling lol. lucky you were able to swap
Mrs_W, Craig, Bank: thanks and yes now I an getting it, the lines are trouble.
Unfortunately all the plots we looked at, all of them have something like 2m and sometimes larger slopes in the area
viewtopic.php?f=66&t=86442
[url]https://forum.homeone.com.au/viewtopic.php?f=66&t=86442
[/url]
A million thanks again
3
A survey must’ve completed by a certified surveyor. This form part of every DA requirement
11/08/2023
Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right…
25/02/2024
Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for…
