Our Clarendon Parkhill 29 Build in Brisbane
Upgrade & Modifications
Facade: Oxford with Render and Cladding to Front and Rear. Bag and Paint to the sides.
Ceiling Height: 2750mm
Front door: 1020mm wide
Theatre: soundproofing & flush panel hinged doors
Study Room: flushed panel hinged door
Powder Room: additional shower
Alfresco: Beam for corner stacker door to the Alfresco
Extended concrete slab (8750mm x 3000mm)
Kitchen Bench: 20mm stone waterfall ends to bench as well as a 150mm extension
In sinkerator & Plumbing to Fridge
3 September
September 6
Slab is completed
September 17
Frame is completed
Week 3
September 17
Frame is completed
September 17
Frame is completed
Wow! House is up within 3 weeks. That is fast.
We started our journey with Clarendon earlier in February. We are building a modified Parkhill 29 with Sapphire Inclusions.
Week 2
September 6
Slab is completed
September 6
Slab is completed
Parkhill . It was on our short list.
Impressive progress in just a month!
Also building this style home with clarendon. Can I ask if you had modfications on the upper floor and if so, what they were?
Thanks.
3
It is Genneral stairs, but they won't deal with anyone off the street. They will only work with clients of project home builders. I tried to but some of these exact…
22/12/2023
4
The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's…
13/06/2024
2
I second taking your plans elsewhere. They're yours (unless you ended up in one of those cheaper arrangements where you don't own the rights and the build will be tendered…
