North facing block: Masterbed upstairs in rear or front?
Ours is a north facing corner block. Right side ie the east side has the secondary street. Neighbour house will be on the west.
So in our double storey house should we have our masterbed in the front or back?
Also any suggestion for the upstair leisure location?
We are currently considering Clarendon Home's Sheridan 38 and Madison 37. Most likely Sheridan we will end up with since it meets most of our requirements with few design modifications. But we are hesitating with the masterbed in the back.
We will appreciate your opinions in this regard from experience/ knowledge.
P.s. the block has 16m wide streets both in the front and right (East) sides having houses coming up on its opposite.
Thanks,
Kazi
Imagine all that light belting in all day in summer! Up to you, hope your not a shift worker.
Heres our plan.
The master bedroom at our last house had walls that faced north and west. That was horrible!
Can you please share your views on the location of master bedroom?
Thanks,
Kazi
Thanks,
Kazi
Ours is a north facing block and that's how we liked it. Designed our home to have leisure room with balcony and sitting room both facing north. These rooms will be used in the evenings.
Our master is located downstairs central west. Definitely not a fan of direct sunlight.
Best of luck with what you decide
We also want to avoid a hot bedroom. Our current home is north-west facing. It has the master bedroom in the front i.e. facing north west. It becomes so hot in the summer! When the sun sets at around 8pm, it's like an oven when we come to sleep.
That means bedroom in south must be a good solution. We will keep it in mind. Thanks all.
Will like to hear more resonings too....
Kazi Pauline
Thank you all.
Kazi Pauline
Kazi Pauline
However I do like the size of your alfresco lovely morning sun and warm during the day.
We also flipped our plan where kitchen and dining are located east and family and outdoor area west. Hoping to get morning sun and be just right for those evening outdoor dinners.
Thank you all.
Kazi Pauline
Kazi Pauline
Hi Emmz70,
The home plan with the grand alfresco was not ours. HatlessChimp shared that.
We have not finalised the design yet. However, we are also going to have a 11mx3m grand alfresco. I just love it. I am also a big fan of bifold doors in grand alfresco. But after going through the blogs, it seems like fly screen is a big issue for bifold doors. The retractable/ centor fly screen is the option but not many people recommended it for its low stamina.
Bifold vs Stackers will be a big mental war for me.
Thank you all.
Kazi Pauline
Kazi Pauline
Hi Emmz70,
My mistake lol 11x3 is still a great size. Best of luck on your finalised plans
A north facing bedroom will get the winter sun and if you have eaves you should block a fair amount of the high summer sun.
A west window will get all the hot afternoon sun.
A south facing bedroom can be cold in winter and can end up having moisture issues if not ventilated well.
I have lived with a west facing bedroom and it was hot hot hot in summer. We currently have a north facing bedroom window and with eaves and double glazing it is better.
Are you having eaves? Are you double glazing? What type of window covering will you have?
Thank you rocketship.
I will consider all these you mentioned eg eve, double glazing etc. If i have the bedroom in north I will try to have a balcony ahead of this. I guess it will help.
But I am douthful about the heat on summer. I don't want to come to a hot bed for sleeping.
Let's see how things come along.
Thanks again for your points.
Kazi (Pauline)
For our next home, we are building a two storey home on a corner north facing block exactly like yours. We are going with a master at the front on the first floor - partly to take advantage of our creek side views and because don't want to be going up and down stairs all day - but also because have heard upstairs rooms can get really hot. So if you're going with a master upstairs, then perhaps it would be at the rear, or else as you said, have some sort of balcony to prevent the summer sun coming right in.
6
The warning is on the sticker on the door too. Second the aluminium powdercoat
24/08/2023
I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second…
16/05/2024
1
hey nedket, We have a similar lot like yours >. just wondering how is it going with your DA application, is the Blue line is the correct solution (offset the rear boundary…
