Help with Brick ID
What about 'Austral Jazz?'
Does anyone else have any input?
I have seen the wall 'in person' this wall looks flat grey without brown or green tones and is smooth face if that helps.
They are lovely though for sure.
I think it's Austral Bricks Ultra Smooth - Jazz (color brick), It's been used on a Provincial Homes display home in kellyville.
http://australbricks.com.au/nsw/bricks/ultra-smooth/
https://www.flickr.com/photos/69137288@N07/6304254354
http://flickrhivemind.net/Tags/ultrasmooth/Interesting
quite a pricey brick if I remember correctly
You think that's a conclusive ID Ponzu? Not sure if it still looks a little blue have to get right up close...
I can almost guarantee. On my house they look grey
Stewie
I disagree with all of the above.
Yeah this was my pick as well..but the Pgh have spoken.. I don't know, I thought it looked smoother like kavehman said too
3
If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with…
27/06/2023
1
can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out
