Split-Level Plan
I've been browsing this for a while now and have just started our building process. Land has been purchased in Blakeview Grove, SA, at the top of the hill. A custom plan has been designed by myself and built by Dechellis Homes. The block is sloped and we have just been told that we need to split the house and that the split has been costed with the garage being lower with 5 steps up to the house. Has anyone had any experiences with this sort of layout as it isn't an ordinary split.
Will
End of the day a split is a split, be it 300mm or 3m the principals are the same it's just the amount of blocks concrete and steel that change. And cost of cause.
The only issue I could see if there was a person mobility issues, where steps create a big issue for a person that's going to be living in the house.
If you don't have the step down, the costs might rise quite a lot more than they have with a split level.
I have thought about the mobility issue somewhat as you can enter the lower split via the shoppers entrance in the garage. In reality if mobility becomes a major issue then I would have to look at how to solve when needed.
Real experience with it, I wish. Still waiting for the house to be built.
from there you go down 7c to the storeroom under the stairs that will be a cloak room and opposite is the powder room. From there you lead into the open plan living/ family, dining, kitchen and out onto the alfresco that is all the same level. There is also a home theater there too which breaks up the openess a little. The ceilings for the lower area are at 38c and the upper area are 31c. All upstairs are 32c.
It was very important to me to be able to have rear access as I have a 3 car garage and work shop in the very rear of my yard that will also have a large glass sliding door to provide extra room for functions etc. Because of the lie of the block it went down about a meter from front to back. To achieve what I wanted the front garage is 6,250mm wide with a clear 3,100mm down the side of the house and the rear garage door is 2,500mm which should be wide enough. So that Garage is at -8c and the lowest part of the house is at -7c. I played with many iterations to make it work and basically I needed no doors along the side of the house so I had to work out how to get the laundry on the opposite side otherwise steps would have been needed which would impede driveway access.
Just hope it all works out.
I'll wait and see how the drawings turn out, they should be back next week. The way it was explained to me is that only the garage will be on the lower level. The pantry access and rear access to the alfresco will all be on the upper level and the house will be entirely on the same level as that. I think 5 steps are involved with my split but now I'm thinking there may well be a further step or two within the house to create a middle level.
I'll see
BTW. Which way is north in relation to your front façade?
1
Move your linen into laundry and access laundry from your present linen space
18/07/2023
1
isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest…
2/08/2023
4
they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo…
