http://i1242.photobucket.com/albums/gg536/Pinkjam1/0a02e151-5048-406e-a863-b65631269162_zpsa0751cec.jpg[/URL]
First time builders trying to decide on a builder
Page 1 of 2
I cant quite see on your plans your measurements from house to pool or distance from fence to pool. If you pick the right pool you can get it closer to your fence or house.
My only suggestion is to change the door from the dressing entrance to the ensuite entrance, as the idea of the moisture/steam/etc from the ensuite going into clothes is undesirable (to me personally). But if you don't share the same concerns, then leave it as is.
We have a meeting with the salesman at the HGWA office this week so may discuss other options. We really did want an activity room too but can't see how it would all fit. Am also concerned about the orientation of our block in regards to the plan as we face north and won't really get much afternoon sun.
The pool is 1517mm from the alfresco and 1502mm from the back fence. And yes I'm already thinking about how to furnish the lounge room with the way you would walk through but wanted an entry area at the front of the house because I hate seeing all the way through it. As for the bedroom I'd change the window so I could possibly put the bed up against that wall. Feel free to give me more feedback
http://i1242.photobucket.com/albums/gg536/Pinkjam1/f6492312-b193-4467-b721-3e81ebaf46f7_zpsa834ec35.jpg
This was the version we had drawn up from HGWA. It may give you some ideas. We didn't go ahead in the end as we decided on another design that allowed us to see the side garden from th living area.
http://i1242.photobucket.com/albums/gg536/Pinkjam1/530f6420-177c-4fee-8e3b-fdcaab604d74_zpsca6f32e2.jpg
Updated version of HGWA plan, tho I still want to make changes to the bathroom.
The plan looks great..few things that comes to my untrained eyes..
1) There is something odd about the master bed room and theater position, the entrance gap eats away a lot from the master BR, on paper its big (5.1*xx) but I think it will look much smaller after the built, especially considering how big the en suite is. I think the Mbr will look much better/bigger if it could be made a perfect rectangle.
2) Sliding door and another 2210 (?) window in the Master br..do you really want to so much light in your bed room? It leaves with the bed orientation in one way only.
3) Is the swimming pool concrete? If so, it can be arranged right next to the alfresco which looks much nicer with glass fencing.
If the window in the master was a highlite window, you would be able to put the bed on the side boundary window.
Other than that, I like what you have done, you've really channelled the view out the back to the pool.
We are getting some changes made to the scullery and laundry and are getting the bathroom changed to a semi ensuite from the guest room.
We are already up to $90000 in alterations as he has based it on the Monte Carlo, which we questioned today as it is a cross between the Bellevue.
The pool will be fibreglass.
Yes I agree, the window in the bedroom is going to definitely be a highlight window. I'm not sure how to get around having the bedroom entrance like that, I think if the theatre entrance and bedroom entrance was moved to access it from the dining room it would look strange?? Lots of doors??
Wow, big house!
With regards to your bedroom door access, how about your theatre entry doors off the dining room wall and not combined in that little nook area to both theatre and Master bedroom? But then again they may be too close to your fireplace.. Unless perhaps your fireplace could go on the family room wall on other side of entrance? Might ask make your dining/family area seem like a bigger more spacious rectangle? I'm just making these suggestions but have no idea of your drivers so they might not be much use!
Have you considered 28c alfresco sliders to really maximise the light into that central dining family area, where the family area doesn't have any external windows? They will be flush with your 31c alfresco which i think will look beaut.
Also, in the powder room/bed 2 area, if you are making that a semi enquire from a guest room, is that Bed 2? If the wardrobe was moved to the bedroom wall that abuts the family room, perhaps you could have a door next to shower to gain entry to bathroom. Then the powered room could be a long rectangle running vertical (on the dwg). Toilet at the top end, then basin on the bottom end and the entry door to toilet on the right hand side. the door could open so it back toward the basin when you go in (i.e hinged on the left). Sorry, this probably doesn't make sense in words!!
Anyway, thats all from me. Hope it all works out for you.
From our experience, increasing construction area/large variations on a project builder's plan is wastage of money. If the variation is not straightforward, I would probably choose another (bigger) similar plan, either from the same builder or a different one. I still regret my variations
Variations of 90k without the pool?
Depends on what the variations are - adding a third garage bay cost us $13k. Adding a portico costs us $2k. Adding 0.5m in length (or is that width, I never know which one it is!!) across the house cost us $4.5k. So it can add up quickly.
The house we priced with 'the other builder' we were going to use added about $70k in variations - but that was after taking the house plan back to bare basics and then adding everything back in. Perhaps that is what they have done here.
Creating a custom design by merging two plans will cost a bit. But isn't that what builders like, the more variations you add, the more money in the sales reps pocket? I'm sure that's why they are so keen to accommodate in the early days!
Just remember if having a fibreglass pool it has to be at least the maximum depth away from the house unless you are going to underpin which adds to the expense. You can go as close as 1m from the fenceline as long as it's not a retaining wall, definately something to consider. we were told the underpinning was 500-600 per metre and they need to go about a metre either side of the pool so it does add up
I thought this would be a popular question but I haven't been able to find any similar posts. Perhaps I'm wording my searches wrong? When you have car insurance and the…
23/03/2024
3
I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop…
