We are also looking at the Manor (Dreamstart) and Milazzo (HGWA) but we are leaning more on this one. Any other suggestions on which builder has nice designs for a small block?
What do you think about this pipe?
In regards to the plan you posted it is quite nice. Some things to consider are just minor:
- Consider doors on both your laundry and audio visual spaces. More so on the laundry. If worried about the door swing, go for a cavity sliding door on the laundry.
- Consider making robes in Bed 3 and 4 double instead of single (especially if you have children/considering them in future, because storage space is awesome).
- Consider how you will ventilate the laundry, especially if you place a door on and have the dryer going. Are you placing security screen door in addition to the sliding glass so you can open glass door for air?
Otherwise I do like the kitchen size.
My reason for asking is I found with a block the same size as us, having a 4th bedroom made some rooms a little pokey. I'm just passed lock up stage now, and I'm really happy with all the room sizes.
There's a couple of other Aveling clients here with a different interpretation of the same plan(Nina71) comes to mind. Check them out also
My build: viewtopic.php?t=62001
just wanted to ask about an exposed pipe that we've been seeing for quite a while now...it is on the side of the house where the kitchen is...I have emailed our contact in Aveling about it this morning but have not received a reply yet...I would also like to ask for your opinion on what you think...should we be bothered about it?...TIA
My guess is it's the pipe from the kitchen sink.
1
No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s
23/07/2023
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
29/01/2024
3
I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to…
