AM I ROBBED?
Page 1 of 2
House is 200sm living and 240sm building
Here is the price summaries (Excl. basic house price):
Site cost:20000
Building allowance: 3000
Basix requirement (water tank):12000
council requirement: 6000
remove trees(2): 3000
Bushfire attack level(12.5-19): 9000
driveway: 9000
raise ceiling(2.4m to 2.7m): 7800
Sounds reasonable? I quite doubt that.
Anyone have a similar cost on a flat land?
Not sure about the other stuff sorry!
water tank again depending on size 12000 seems alot
This will be a rip off as plumbers, councils and the building company rarely have any idea plus advantage is taken of the new home owners as they lack the required knowledge. Most people also end up with a sub standard and sometimes non compliant system.
I take it that the onsite storage has a requirement for bush fire detention. How big is the required tank?
driveway depends on what sort you are looking at mine is for a triple garage in aggregate and cost 9500
mine is double garage and drive way will be 5m in length
water tank I think is 5000 L
I just got a flat land in NSW and got a tender from my builder. A famous one.
Site cost:20000
driveway: 9000
Site cost:20000
driveway: 9000
May know who is your builder and your location? I just removed 1 tree today, cost me 650$
Water tank for mine, 3000ltr slimline tank 7800$
Unjustified expense. Probably $4k too much. If you post a photo, I will give you an evaluation of the install.
We were quoted around $5,500 for a 5000 litre slimline water tank and pump from our builder, I got my own quotes and can get the same tank and pump for $1700.
This is what I like to hear but was the $5,500 just for the tank and pump?
littlefox80,
Do you want to start a specific thread in the Eco Living sub forum in regards to your tank? You have asked about several things and it gets messy on the one thread. Threads like this in the "Building a new house" sub forum tend to get lost.
We're upgrading the water supply in our home - instead of down pipes leading out to storm water management (or the ground) we're "upgrading" to allow for water collection, we'll supply our own tank and pump, and then the builder is plumbing in two taps for rainwater (one in the kitchen, one on the outside of the house). So he's making sure the gutters are set up for collection correctly and feeding it back in, we're doing the storage. What are you getting/doing vs the builder?
$5500 was the tank and pump installed. Actually I just remembered they did charge me an extra $800 for upgraded downpipes to install the tank I supplied
I assume that they used 90 mm round PVCu pipe. This is little more than $2 per metre.
It is hard to comment accurately on the $800 mentioned but this sounds unbelievably good as you probably had a slab, the tank overflow to connect to storm water and the plumbing costs for connecting to the toilet(s) as well as other items like a pump cover and an outside power point.
We were quoted around $5,500 for a 5000 litre slimline water tank and pump from our builder, I got my own quotes and can get the same tank and pump for $1700. I'd suggest taking it out of the contract (tell them you will supply your own tank). Also I'd look at getting your own quote for the driveway, ring around a few concreters you will get it much cheaper. How big are the trees? We had a couple of small trees removed for $200, again ring around!!
Thanks for these! I just found I really know nothing ...
Site cost:20000
driveway: 9000
Site cost:20000
driveway: 9000
builder is BW, newcastle ... I left a message on you blog ...
That's why after got a tender, move to allworth homes. Did you try other project builders?
What design you choose with BW?
littlefox80,
Mate, most of the project builders charged too much on the Basix requirements and site cost
I asked on the tank and the fencing if we could supply our own and the answer was no.
We ended up going with another builder (not for that reason though)
The pipe was quoted as "Up to 35 meters of 100mm diameter round DWV PVC downpipes with rectangular downpipe pop on home for rainwater tank use". The $800 also included plumbing for connections to toilets and main water supply (incase the tank gets low), connection to stormwater and an outdoor powerpoint. We are to supply the tank, pump (and cover), and prepare the base.
I am considering my second tank and in Tassie, Tankworld is offering 10000 l tank with pump for $ 1640 delivered
http://www.tankworldtas.com.au/specials.html
Add for tank base and connections
