NBN ... Confused
Page 1 of 2
I am hoping someone who has connected to the NBN can provide some advice and some photos of what I am trying to envision... We are in an NBN estate, I am planning to move in about a months time. Due to Telstra's slow connection rate, I organized or this to happen Monday. Today the NBN co. rang to make an appoinment for organizing the connection, talk about efficient but this has raised some concerns for me. Along with the phone call, they emailed me this guide...
http://www.telstra.com.au/internet/down ... 210212.pdf
Hope that link works... On page 10, it talks about what needs to get installed where... And to think of suitable locations, at our electrical appointment they suggested the garage, but clearly on page 10, it states not the garage... I am beginning to not have faith in my electrical advisers... So I am asking the experienced in this area... Where do you have these devices located? Can you provide me with a photo so I can see the location that is suitable. Yes there are photos in the guide but until I have a frame of reference that is useless. Thanks in advance.
I phoned NBN and they told me garage is not the best location because it is not insulated. However, when I went for my electrical appointment, the consultant (Argus electrical) said that they usually place the NBN provision in garage. So, I'm also looking for someone who can shed some light to this...
On a side note, one of my friends have fibre optic service (Opticomm not NBN). He has the device (similar to NBN's network termination device) placed in the garage - and it's been working fine for him.
If opticomm looks the same as NBNco, then that would reassure me... Thanks again
Happy to stand corrected, but I think this is specifically referring to detached garages - e.g. not part of the main building structure.
I personally would not install my equipment in the garage - due to the increased risk of dust and sometimes garages are not as well insulated as the rest of the house so they get hot.
However if you check out the Home Theatre forum, you'll find plenty of people that do keep their servers etc in their garage. Plus's of doing so- they are out of the road and well ventilated.
Did you have data cabling installed in your place? A great place to place the NBN NTD, would be where all your data cabling routes back to, or near a point which does.
For example, my switch, modem, router and network storage all sit in a cupboard in my media room (which is ventilated to outside)
Just to clarify - the box in the garage, is that the Premise Connection Device or the Network Termination Unit?
http://www.nbnco.com.au/blog/gallery-nb ... ation.html
The network termination unit... Thanks that's a great link and what I was after.
Now it raises up my concern again whether I should have nominated the study room for the NTU location... Helppppp....
it will be the Network Termination unit (NTU). the Premise connection device will be located outside. The NBN provision that I get from my builder also includes a conduit from the outside wall to inside garage where the NTU will be located...
I think you feel my confusion and frustration.... Lol
http://www.nbnco.com.au/assets/document ... ablers.pdf
If you refer to Page 2, they do install in garages so it must be as atom_ute said, they probably means that you can't install in a detached garage. Talk about confusing! :S
https://www.youtube.com/watch?v=PsOGXiZ ... gs5BeOVDsw
Most existing houses dont have wiring for data points around the house, so getting the NTD installed in the garage makes zero sense. If your house is coming pre-wired for data to the Study/Theatre/etc you will have a central point for the wiring in your house. Ideally your builder should have provisions for the either form of fibre coming into the house as well.
-near power pt
-near cool dry ventilated area
-out of harms way
-near existing phone or network cabling
-easy to access
I would think a garage also qualify all of the above (except for point 4). Yes?
?_?
If there is going to be conduit installed during a new build (with a pullwire) so the cable can be run from the Premises Connection Device (outside of house) to the Network Termination Unit (inside connected to the modem, etc) then the conduit has a maximum number of bends.
“Maximum total (cumulative) bend angles: 270 degrees between accessible draw points”
That’s why the garage at the front is convenient. If you are going to locate the NTU at the back then you need to ensure that you have access to multiply draw points along the route.
9
If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify…
