BUILDER INVOICING LOCK UP & BRICKS JUST STARTED!! WHAT THE?
Still curious to see if others have experienced getting the 'lock up' invoice before external cladding is completed...
At least that's how I interpreted the wording in our contract!
2
They create an invoice on say the 10th of a month, mail it out on the 12th , you get it on the 13th check the mailbox on th 14th, a Friday and it states payment in 5 days from date of invoice or your in breach of contract, whether the job is complete to satisfaction or not. I like to let them sweat for a week tHen call the bank and start proceedings.
Has the builder ever gotten back to you, or completed anything else in the time stated ?
The answer is NO . Here enduth the lesson.
Water isn't particularly kind to plaster sheets.
What about insulation?
I work for a small house builder and so i have learnt a lot of what goes on.
I would have a look at your contract and see what needs to be completed for that stage to be paid. It is up to the builder if they want to put in the internal gyprock, but to me lock up is the place is secured. External doors and a garage door. If the brickwork has only just started I would be holding off on payment.
Are you using a HIA contract? I think for memory a stage to be claimed, the majority of the work has to be completed.
My only concern with paying builders early - we have had a few people come to us where the builders claimed for stages early and people paid them only to find the builder went into liquidation. The problem you have with this, is if another builder has to start, you have paid for more work than has actually been done, leaving you in a bind.
Maybe go out to site, have a look at the work and correlate it with what is in the contract. If you are concerned at all, tell them that you are going to hold off signing off the claim until it is completed. Remember when you sign off for the bank, you are signing that the build has been completed to that stage.
Gyprock can also handle a bit of water as long as it doesn't get completely saturated or will be persistently damp as a result of getting wet initially - it's the mouldings (skirts/arcs/cornices) that suffer from exposure to water - but having said that a SS wont proceed with the hanging of any gyppy if it is going to get consistently wet over an extended period or there is a potential for it to become saturated (because then they'll be footing the bill for getting the plasterers to come out and re-hang the affected sections of gyppy).
As for the lock up thing - in pretty much every standard HIA contract each stage is either a specific milestone or a percentage of works completed. For lock up the house does not have to be completely "secured" if some works from the fixing stage have been completed in advance.
I would be equally as careful with advice such as that given above - if the builder can demonstrate that they have completed the required percentage of works by knocking off some items from the fixing stage in lieu of items yet to be completed from the lock up stage then you may still be liable for penalty payments as set out in the build contract.
9
Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out…
