Blockout shutters on a new house
I've just got a couple of quick questions relating to Blockout Shutters. I'm going to be building a new house soon (single storey) and I do want Blockout Shutters on the house for added security and privacy. My questions are these:
1) Is there any advantage to adding the shutters to the tender for the initial build, or should I most definitely have them added on after handover? I'd assume that by getting them added in to the initial build cost that they will only end up slugging me with additional mark-up, but I wonder if there's any advantage with regards to installation process?
2) Are there any brands other than the original "Blockout" Brand that I should be considering? Security is an important thing, I don't want cheap ones which are easy to pry out of the tracks with a crowbar or anything like this.
Any advice appreciated greatly!
Thankyou
Ryan
If you want electric motor operated they usually put the switch next to the window. It can be difficult to put it asnywhere else. You can get remote control / battery operated motors but they are more dollars.
We did ours during the build so the switch to operate the shutter up and down is in the same gang as the light switch for the room.
Crow, that's what I was particularly interested in doing also - having the switch for the shutter located with the light switch so that it's not necessary to walk up to the windows to open the shutters. Sounds like that's a massive advantage to having it done during the build. Maybe I can sweet talk the site supervisor into allowing me to arrange for extra wiring to be run during the build so that I can still save my money and have them installed after handover.
We have prewired for a second shutter and the wire from the light switch is run to the eave above the window so that if we go ahead they can lift a sheet of iron and connect via the junction box. In the meantime the wires will not be connected to power.
Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is…
13/05/2024
3
Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is…
