Glass splash-back standards and tolerances
Building a new house, the kitchen glass splash-back has been installed and we have a PCI coming up very soon.
The splash-back is meant to be 650mm high, but after having a look at the installed splash-back, it is at-least 4-5mm short at the bottom and has been filled with sealant/glue( 4-5 mm thick glue). The splash-back is 10mm short horizontally.
Does anyone know what the standard and tolerances are with regards to the size of splash-backs.
Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1…
26/05/2023
4
I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more…
