Custom Design Project Builders
I'm currently planning to build at Nundah on the northside of Brisbane. I've got a narrow block (13.5x40.5) so designs a pretty restrictive on that part. As I have a close relative who is an architect I've had my own custom plans drawn up for basically nothing.
After doing a fair bit of reading on these boards it's obvious that going with a private smaller builder it is always going to cost more than a project builder based purely on their buying power. Another advantage of going with a project builder is that the process is simplified. Are their any project builders who will consider looking at custom designs and is their anyone who has gone down this path?
It's a 2 storey home at around 400sqm.
If there are any builders people recommend we get quotes from please post them here (or send me a pm if you prefer)
Although you have to shop around to find a good builder.
My current quote from a custom builder is around 9.5K / square. So less than $1100 a square metre, including heating/cooling.
Well that gives me a little hope. Any adivce on shopping around for a "good builder"? Things I need to look out for?
The builder I've found also did the drafting for my house. His plans were brilliant and it took into account everything I wanted.
He is more than happy to show existing homes he has built, although I won't know until the build is complete how good this builder is
We have a custom design and are currently looking for a builder. We've found a number of project builders more than happy to take our design directly then draw and cost it up. Unfortunately it's in WA so I'm sorry that doesn't help with recommendations.
They've generally found a design of their own that's closest to it and then worked from that as a base for costing and spec. That way you're not paying for a completely unique design because most of them simply aren't structured in such a way to make that cost effective.
Good luck with your search
anise
3
ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your…
22/06/2023
Following these simple steps will help you mitigate unwanted costs, have your expectations met and give…
15/01/2024
3
As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is…
