recess ceiling - does it weaken the structure in any way?
Page 1 of 2
This is what they have done to my Kitchen. It has a drop and a recess. There are 10 timber beams that run across the top of the entire area so it is 350mm apart to secure the floor above. I would think this would be the same case as if we just had a recess and no drop ceiling.
what do you mean. Do you have a drawing?
no - i don't have drawing. still considering whether to opt for recess ceiling in entrerance or not.
They don't actually cut anything to do it... it's all purpose built around it.
We have a recess ceiling in our entry and we haven't had any problems. I might have a pic of it at frame stage... I'll have a look.
i thought they cut it - i think i have seen in few houses being build in Perth. Pic will be good if you can.
thanks
has any one got any technical information if recess ceiling weaken the structure in any way at all?
short answer ..no
long answer .. no,no,no,no,no,no
relax, no one would approve a structure if it didn't meet regulatory building codes.
short answer ..no
yes - i know it would meet regulatory building codes - but there is always a range of standards and the builder has to meet only minimum standards. once the minimum standards are met, it is approved. It is like plastering the new house. Sometimes there are so many dents etc in plastering and if you ask them, they say it meets the minimum standards that they have to maintain.
I can't see that engineers would continue to allow them if it weakened the structure
May be i should have said - effect the structure and not weaken. i think i should edit the subject title.
I'll take a pic of the ceiling tomorrow to see it when it's finished. I can't get in the entry at the moment, it was repainted today and it's blocked off so the dogs can't get up there.
This is at frame stage. You can see on the right, above the door frame, where the timber comes across, is braced, then drops down to above the door frame and that is the ceiling height through the rest of the house.
short answer ..no
I understand where your coming from , just to put some perspective on the matter, most tradespersons will adhere to the maximum allowance e.g drill the largest acceptable hole in stud ..so in actual fact that stud then becomes the weakest permissible structure allowed, yet no one blinks an eyelid ..because it's acceptable according to the code.
have I explained adequately?
If you are going to start questioning the structural integrity of a coffered ceiling then you may as well question the structural integrity of the entire ceiling, it's all constructed using the same principles and span tables.
The coffered ceilings I've done have been constructed using LVL's to span and hang the ceiling joists, there is no way they compromised anything, if anything I'd say the ceiling was more rigid than a standard ceiling.
By the way I'm in WA, but span tables and building codes are fairly universal (in Aus at least).
If by recessed do you mean the appearance of a raised portion of ceiling. if so, then this is achived by actuall costructing additional timber bulkheads around (usually the outside of) a room. It is quite common for the kitchen ceiling to be dropped by 200 - 300mm, and then if a 500mm wide bulkhead is created around the room, then an illusion of a recessed ceiling is created.
I think the OP is talking about a coffered (recessed central area) ceiling rather than bulkheads.
Fairly common in WA.
Hello I've just bought a house where the slab is lower than the street, (but roof is higher than the kerb). So there's some negative grade at the front. The yard very…
23/05/2024
3
hallway light switches outside each bedroom. Life saver.
