6 * rating
Page 1 of 2
I heard that after May we need to have 6 start energy rating for all the homes.
How do you all are achieving 6 * energy rating.
Please advice
Thanks in advance
Srini
And external wall insulation...1000 bucks for 22sq house for r2.0 bats, totally worth it!
Ours will be 7 star, but it also is dependant on orientation of the house, (which you cant do anything about due to your block) window coverings, ie curtains
which we will get after
There are some better posters on here who will advise you better, but this is just from little ol' me and my 7 star house lol!
Pos
In Vic we must be 6 from may this yr
On the Northern side, it's mostly half size windows.
However, i got 6 stars!
Maybe the insulation batts made a big difference.
1. Orientation of the house.
2. Insulation used in internal walls and it's type.
3. Windows size and double glazing helps a lot.
4. Placement of all the windows throughout the house so that it helps well in cross ventilation.
My house has got an energy rating of 7.5. With all of the above and in addition to that I have gas boosted solar hot water. Heating is through gas. Recycle water ( it is mandatory in my estate). I got 9feet ceiling and ceiling fans installed in the house which consumes less electricity as compared to any other cooling device and also does not give out any gases bad for the environment. My roof pitch is also 25.5 degree. Hope this points help
http://www.kingspaninsulation.com.au/Pr ... rview.aspx
Its looking like the most cost efficient way to do it, the only 2 possible problems are
1) Getting your Brickies (possibly the most sensitive trade around) to install it
2) Storing it on site, as a roll takes up a fair amount of space.
Basically, the product is permiated, so it won't allow condensation transfur (it can "breathe") and it will increase the "R" value of your external walls from 0.6 to 2.1. Estimates at saving a possible 10% on your energy bill.
Thats all that I really know about the product.
One thing is for sure... The cost WILL be passed onto the client, however we all will benefit in the long run.
Double glazed windows throughout
600mm eaves
Insulation throughout - R3.5 to ceilings, R2.0 to external walls & R1.5 to internal walls
50mm blanket insulation under roof sheets
So we went from 6 to 7 stars when all the errors were corrected. they had all the info supplied, they just didn't look at it!!!
Makes you wonder.
http://www.nathers.gov.au/eer/index.html
What is rated?
A dwelling can be rated before or after it is built. The rating depends on:
the layout of the home
the construction of its roof, walls, windows and floor
the orientation of windows and shading to the sun's path and local breezes
how well these suit the local climate.
Energy consumption by hot water systems, lights or household appliances is not part of the rating because those fittings are usually replaced several times during the life of the building.
What is rated?
8
10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need…
18/02/2024
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
25/03/2024
5
My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance >
