Does anyone have EasyGas DownUnder from ELGAS?
Has anyone on here used it/ have it?
I figure I'll need to organise a quote with a plumber as soon as I confirm with the builder where the gas hot water system will be.
Is that correct? Does it meet up at the gas hot water system?
I spoke to the SS about it and he seems apprehensive. Seems not many people are aware of the option. Perhaps natural gas is just far more accessible these days.
Any info is appreciated.
Here's the website if anyone is interested..
http://www.elgas.com.au/for-home/refill-gas-bottles-lpg-supply-bottled-gas
Nettie
We thought the cost for space heating was huge.
After the first year we converted our space heating to a split system reverse cycle air conditioner which paid for itself after a couple of Winters in gas saving.
If I was building again without natural gas I would probably go for the Elgas for cooking only where a couple of 45kg bottles would be fine and have minimal installation cost
We have gone over all the pro's and con's and essentially we are having gas boosted solar.
I''m actually more wondering if anyone has got underground lpg and can provide any feedback.
cheers
Nettie
We have and Elgas Easydownunder and love it.
We use it for the cooktop, bbq and our hot water is instantaneous gas. We were the first ones for our builder ( I did a lot of leg work regarding this and convinced them that it was a good thing for us to have), the builder worked in with Elgas and we paid for this via a variation around $900 including elgas costs. Elgas came out and did a site inspection so that they could ascertain where the best location for the tank would be as it needs to be in the front yard and easily accessed by them. The gas tank was delivered, the hole was excavated. The gas pipes went in as usual for the build, and then ran to the gas tank location (a hole in the ground) . The elgas tank was installed by the builder/ plumber (elgas certified) and filled over. Once the plumber connected the pipes to the installed elgas tank, it was filled, the plumber then came out and tested it provided a compliance certificate which is affixed to the tank.
For the BBQ it stayed as LPG but we had to get a new hose made so that it had an LPG connection on one end and a Bayonet connection on the other I think this cost us just under 50 bucks.
We are in a bushfire prone area so are very happy that the tanks are underground. I have some photos of the tank hidden somewhere on the computer I will see if I can find them. It will probably be later in the week before I can upload them.
Hope this helps,
Michelle
I asked my builder about this underground tank option and they didn't seem keen on the idea. I was told that they would have to dig a hole in the ground and then have it reinforced with concrete which would bring the cost up into the 1,000s. I am beginning to wonder whether they really know what they are talking about. I'm just wondering what was done to your hole in the ground prior to placing the tanks in and filling it?
HTH
Michelle
Cheers
Karen
It's costing a lot more than I expected and I'm not sure I'm going to proceed. There seems to be no advantage to having the underground tank other than aesthetics.
I'm in Gold Coast area.
I'm just about to get a quote here in Lake Macquarie NSW from an Elgas qualified plumber. Will let you know how I go but from initial enquiries some time ago I'm pretty sure it wasn't anywhere near that. I think It was less than $1k... I hope my memory is okay lol
Cheers
5
I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides…
20/09/2023
7
i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one…
3/11/2023
1
Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single…
