Optimal size bedrooms
Page 1 of 2
I walked on the slab the other day and I find it's really small!!
Maybe I can't visualize it well without walls and stuffs. Hopefully it'll be bigger than what I perceived!
The room you said is 3.2 x 3.4m comes to 10.88 sq/m. That's a bit smaller than average. Of course more room is nice to have, but every extra sq/m of a house will cost more to build, and to paint, fit floor-coverings etc.
I think for bedrooms other than main bedroom, its best to have a nominal width of 3.65m. (This allows for full width carpets or floorcoverings with minimal wastage. Then the length can be as much as you can make it. If I were planning, I'd make it about 4.2m long. This would be a nice size of 15.33sq/m. But of course, it depends on how the overall floorplan works, and where you need more room.
Cheers!
Ash.
Pfft....yet another reason to have floorboards....
There's something wrong with me isnt there .
Just picturing driving thru a new estate somewhere and all the people standing on their slabs frantically swinging cats around.
Not at all!
Well they have a use after all....
Main beds are in the 4 by 5 or 6 range. I`ve seen a few 2.7 by 2.8 or 2.9 rooms and it`s tiny.
Something in the 3.5 or 3.6 range is pretty common though.
Not stalking, just saw you mentioned somewhere the other day in a carpet/flooring thread and that you were in perth and clicked...
Gday, still at design stage with my house, has anyone decided opn an "optimal size" for bedrooms, especially children(who then grow into teenagers!) I got back designs but their rooms were only 3.2X 3.4(plus BIR) but when i measured it on ground it seems really small!!
Sounds around average, definitely not small when comparing to most current plans. You'll fit a double or a queen bedroom suite in that for when they are older. It's not so much the size, but a combination of size and window/door placement so that furniture can be placed easily. We have one minor bedroom that is 3 x 3.6 but due to window door placement, can really only fit a queen and bedsides. Another bedroom is 3.3 x 3.4 and due to pacement of windows and doors can fit a queen bedroom suite (including tall boy.)
3.65 x 4.2 for minor bedrooms? Pretty unrealistic in the current housing climate unless it's a custom build and $$$$ and size isn't an issue.
Our minor rooms are all 3.5 x 3.5 and again this is a good sized room. We chose to have sliding doors on the robes so as to cut down on the impact an open door can have.
You make some good points there Joles, and others' input as well.
The original question was "what are optimal sizes" so I offered what I think is optimal. Sure, it may be unrealistic, but it is optimal!
And although some may choose other floorcoverings than carpets, a nominal width of 3.65m makes a lot of sense. Whether its a length of 2.7m, 4.2m, more or less, having that width is a good standard.
Ash.
6
Hi, Have fun, remember bedrooms should feel relaxing and inviting, the last space you see before sleep and the first you see when you wake up. Make sure it makes you…
18/07/2023
1
All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers.
20/07/2023
Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks
