Should this bother me?
We just received the invoice for our frame stage.I told our building supervisor that there are cracks in the window's wooden frame.But the supervisor said that if the frame inspector has given it a thumbs up,it is alright and I shouldnt bother.I have attached the pics below.please let me know if this should be corrected or it doesnt matter.Thanks in advance.
it looks like it is just on one window, is that right?
Now feel free to ignore everything i have to say because I don't know how building company's work nor have i built, (but i'm sure lots of others do), but you say that the inspector gave it the ok. Is the inspector responsible for signing off this stage of the build from a completion / safety etc point of view? If thats his role then i would think that a crack in the sill doesn't matter to him to be able to sign if off. It isn't structurely a problem, or going to cause a problem to the window.
But for you it matters because someone has to make this crack disappear. So someone has to either putty and sand it etc so that when its painted you'll never know it was there or an architrave will cover a lot of it. So I think i'd be interested in asking your supervisor what it will look like when its all finished and then if he says you will still see the crack, then go from there, if he says it will get patched at a later stage, then at least you know
ok people with experience...what's your view
Thanks Little Buddy,
Every pic in the post represents a window.so I guess,in total there are 4 windows with the cracks in it.I am waiting for the Building supervisor to get back to me.He had said he would call back today after I objected him not responding to my queries.Still no call.Will have to remind him again tommorrow.Hate builders
Don't stress. these things can be fixed. Just see what he has in mind first. you might find that he knows that it will be fixed later on. And if his answer satisfies you then all is good.
Let him give you his plans / thoughts first
are thos eincluded in the frame stage inspection, i wouldnt have thought so
It would "bother" me certainly, as any imperfection in my new house does, but not enough to get mad about or demand a window replacement, no way.
finally got hold of the builder.He said that the carpenter would be coming in after the insulaton.He would have a look at it and decide if that can be fixed,or else they wil replace the whole wooden frame.Thats some relief
I am currently getting quotes for 600 mm high footings for a 14m x 7m (total dims) expandable house The number of posts required are 36, layout attached It is a level…
22/04/2025
5
Ground levels under the house should always be above levels outside to prevent water getting under the home, if not the your drainage should be designed to do so.
1/06/2025
Hi Everyone I hope you are all enjoying your…
