Anyone built with Scyon Matrix Cladding
Just wondering if anyone has any experience with this product, good or bad.
Thanks so much
Greg
Kind regards
Greg
That Vitrabond and Alucobond has also caught my eye but not doubt more expensive but by how much?
Ed
BTW... Lazarus only came back once... unless you know another Lazarus...
We have seen some poor jobs and are concerned that our carpenter may bugger it up. I am sure there must be a bit of an art to getting it perfect.
Also do you know how they hide the screws?
It cuts very cleanly with a hardie blade installed in a circular saw.
The reason I chose the axon cladding is because it has a ship lapped joint which means it goes up very fast. You can also use a brad gun to install so if you have timber frame it can be fixed incredibly fast. All the scyon products can be gun nailed which speeds up installation. You use stainless steel ND brads and there is no need to fill heads, just paint straight over.
The Matrix is a little more involved for installation.You need to fix the axent trims to the frame first and then fit the matrix sheets to that while maintaining the shadow line.
It looks nice but installation cost will be higher.
Here is the completed upper floor, waiting for the painter.
I have been doing a bit reading and I notice for the matrix paneling there are four options for fastening:
1. C25mm 16 gauge 304 stainless steel brad nails.
2. 2.8x30mm corrosion resistant fibre cement nails.
3. 25mm countersunk stainless steel screws.
4. 25mm wafer or pan head stainless steel screws.
It says a two part epoxy flush sealer and then a base coat is used to fill the countersunk screw heads. Obviously a lot more work but better finish.
It seems that with the nails there is no filling of the heads, which I think would be ok at a distance but not good where the paneling is on a balcony.
Anyone know what the nails end up looking like close up once painted?
Great product... we designed our windows and doors to take this product directly into the head, sill & jamb... so it looks good and is weather tight on its own or with the JH Axent frame around.
Ed
Ed
Here's the Scyon Matrix against our window... (FYI this is the awning window with venetian blind inside the double glazing)
5
The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it…
21/11/2023
Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them
23/04/2024
1
I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks…
