Plank embedded in slab and drainage pipe for evap cooling
1) Plank embedded in slab
This plank was "left behind" after slab pour, SS told me during PCI that the protruding portion will be cut off and the embedded portion will remain as it is. The embedded portion runs alongside the slab for water tank and HWS. Does that sound right? Not sure if the embedded wooden plank would rot in time to come?
(photo taken a while back)
http://i780.photobucket.com/albums/yy81/rocketleaves/kitchen%20bench%20cupboards/IMG_7927.jpg
2) Drainage pipe for evap cooling
This pipe sticking out of the bricks is a drainage pipe for the evap cooling unit (not sure if I heard it correctly from SS). Apparently there are many ways to drainage for evap cooling unit but this is the way done by S1monds, claimed by SS as a effective way. Again does that sound right? The pipe is big enough for insects to come into the house.
http://i780.photobucket.com/albums/yy81/rocketleaves/kitchen%20bench%20cupboards/IMG_8090.jpg
Hmmm astuck form board
why was there a form in there anyway?
That is a shocker...
Maybe the person who put the slab down could be used as a lever and hammer
to get it out
As for the pipe, its the first time I've seen it done like that, but I suppose if you want to keep the furry beasties (& others) out maybe you could use a small piece of flyscreen mesh to cover it? The water will still be able to flow out but creepycrawleys won't be able to get in. Just a suggestion.
The slab thing is just unbelievable.
rosemi - putting a mesh there is feasible but it would be very layman to use a rubberband to fasten a mesh. I am going to push SS to get the plumber come up with more professional solution (mesh cap??)
Kek - before plastering, I saw this pipe leads all the way from side of wall to the roof, not sure where it leads to after that (evap cooling unit not installed then).
But ask what can be done.
Assuming it's connected up to the outlet from the unit on the roof, it should work - and it'll be a neater finish than a pipe discharging water onto the roof. In the interests of conserving water though, I'd see if there's a way you can collect the runoff. Ours runs into a section of the spouting that feeds into the rainwater tank, so it gets re-used for flushing the toilets. Every drop saved helps!
Perhaps you can come up with a simple DIY solution post-handover and use the water on your garden.
Kek - SS said a cap will be put at the terminating end (plumber will look into it). I am assuming the cap will be perforated with tiny holes (SS wasn't sure). To get the pipe connected to my water tank will be really pushing it as water tank is 6m away (though they are all along the same brick wall), with a 5000 litre water tank I will just have to let this pass.
ONC - SS informed me that the WHOLE plank would be removed and Termguard pipe put in. YEAH.
Or you can just stick a container under it and empty it onto the garden when it fills up.
Need some enlightenment from all you fellow H1'ers
Hi rocketleaves
Have just picked up on your post re the above. The outlet pipe for the evap cooler is a good idea by Simonds....ours has been done this way....... it should however connect into a waste pipe. It would not be permitted to just drain onto the ground as water coming from the evap could contain bacteria.
Onc, the wooden plank was chiselled off. I saw wooden chips around the watertank slab and the area concreted over. I supposed that should be ok. Thanks for asking.
I guess not.
Oh well.
Best of luck.
Ed
you will know soon enough if the bottom section of the board is there
because the new section will pop out in no time and reveal the story.
Just keep an eye on it
1
The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure…
15/10/2023
3
Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping
