Spot the problem
Page 1 of 2
This is a photo of our housebuild. It is progressing very speedily, which is great.
However, today I noticed something, and was wondering if it is noticeable. I hope it isn't !!
Answers appreciated.
I got this message:
"Allowed Extension Groups and their Sizes
NOTE:
You are normally allowed to attach files within this Forum,
but since no Extension Group is allowed to be attached here,
you are unable to attach anything. If you try,
you will receive an Error Message."
thanks Pasey...i think I've got it.
http://i209.photobucket.com/albums/bb55/ASKMelbourne/a.jpg
Thanks Damo...is it that obvious?
What do you think I can do about this? I'm sure the bulders are covered by some kind of clause about brick variations between batches.
Would you all say that this is a major flaw?
The 1st storey is a different shared to the 2nd storey
Has anyone else had this problem? I can understand how batches can be different...but it would have been nice if they've ordered all of the bricks in one go.
Would it turn you off buying a house with this kind of issue???
the front bricks look more uniform and they are under full light so it could just be an optical illusion... ie. could it be variation in mortar style casting more shadow on the lower floor?
They completed the bricks on the ground floor a month ago..and then ordered the bricks for upstairs.
Oh well..and to think my parents were going to build with them. They will reconsider now, unless we get some compensation.
Anyway, I thought they tint the bricks so that it matches? It's kind of like my issue with our tiling - if you can see it with the naked eye then it's something that definitely needs to be fixed.
What does your builder and supervisor say?
Another forum member had similar problem when some brickwork was repaired and is having the lighter brickwork tinted/dyed...the link is here https://forum.homeone.com.au/viewtopic.p ... highlight=
Personally, I wouldn't worry about it.
But he is much luckier than you, because they check their site almost everyday and was able to pick it up very early in the stage. The brick layer only used some of the bricks and our friend demand it to be stopped right away.
From builder's point of view, they insist it's not their problem as they ordered the same brick and they refused to re-order. Our friend just refuse to accept that, after lots of phone calls and arguments, with the whole construction delayed for more than a month, the builder finally give up, remove those bricks in the wrong colour and re-order new ones...
I think in your situation it's a bit too late to ask they to knock down those bricks and re-do the whole wall. You can try and fight for some compensation or rendering...
6
Thanks for the advice mate. I'm on it.
11/08/2023
12
I don’t think so as the floor area over 300 square meters then it is class 3….
