Powerhead for Ducted Vacuum System
Are you happy with it?
From whom did you buy it?
TIA
For instance we have a Nilfisk ordinary vacuum and a Valet ducted sytem - the powerhead from the Nilfisk fits onto the wand of the Valet without spending any extra money.
I was all ready to go out and buy new bits and pieces before the installer told me about that just before Christmas.
Ash.
Southies - just a quick thought. Have you previously had a powerhead with your previous vacuum?
I thought I was happy with our ducted system until I tried my mother's new DYSON on our NEW carpet!
OMG, it sucked out sooooo much dirt & the carpet was only 4 months old at the time. I've decided that when this system dies, as I anticipate it will in a few years, I will be switching to a DYSON, come hell or high water
Quote:
The best to get is the Turbo-cat. I think Aussie-vac sell them
Thanks Ash
Some have a separate powercord, batteries, etc.... The turbocat apparently
....harnesses the airflow of the ducted vacuum system to generate maximum airflow and deep cleaning power.
OK, so how does it effectively do this if it uses airflow, the same as any other system be it ducted or not ?
Wouldn't an electric powerhead be more effective ?
Ash.
Good ducted vac companies should be able to show you various units and demo them, so you know how they work.Ash.
mmm...that makes sense Ash. Will look into that - thanks again
http://www.aussievac.com.au/pages/defau ... e_id=25312
I see there is a new type of Turbo cat too. I have used the original one for vacuuming with my truck-mount. It HOWLS with the airflow my machine produces. I would suggest you look at them, but make sure it is driven by a high airflow system to be efficient.
Ash.
An electric powerhead will work more like a tractor with a strong consistent brush speed.
Which is best for YOU depends on the power of your vacuum system, and your choice. Suggest you ask to try before you buy.
Ash.
We have now moved into the new house and our ducted is amazing and the suction is sensational, I guess it depends on what type you have.
A Dyson and a good ducted system can work hand-in-hand to cover many cleaning jobs in and around the home. Have both!
And YES, every ducted vacuum installation will vary, and also vary from each outlet. This is why its important that it is well designed and engineered, with duct piping all cut & joined neatly, and piping routed so as to minimise bends and distance from the vac unit. Best units will have a good powerful vac unit, postioned carefully, and minimal pipe distance with few bends & restrictions.
Ash.
Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room…
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),…
