What is "Expansion Joint"?
Found this "Expansion Joint" thing been marked almost every 3 to 5 meters around the house on external brick walls. Can any one please tell me what is "expansion joint"? Also, it would be even better if you can kindly provide a photo. Thanks!
Cheers
Allan
http://building-our-first-house.blogspot.com/
I think our soil test (m class slab) reccomended 6 metre spacing of joints and to be placed within 4 metres of any external corner of the house.
Have a look at some of the blogs or at your display home and you can see them easily in the brickwork....
Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.…
21/01/2024
Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio…
