Brick vs Besser Blocks
We a just about to sign our contract with Adenbrook It's a 2 story home and with have a smooth render & paint finish. We can choose eith brick or Besser blocks.....at no difference in price.
Does either have advantages over the other? Thermal or strength qualities?? If using Besser blocks should they be filled with cement when being laid??? Some have told us that cement render sticks to Besser blocks better than brick...is this true??
I must say, this site has been extremely helpful, so thankyou to all those responsible.
Cheers,
North Lakes
1
there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel.
22/12/2023
6
Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable…
14/06/2023
17
Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window…
