Could someone please help to check if this Raft Slab plan is designed correctly for the slope block (about 1m at the rear of the slab)? Builder said this is incorrect because it will be too high but our engineer said nothing wrong with it.
Incorrect Slab Plan ?
Hi team,
Constant
What you have posted isn't really readable and also needs to be compared to your architectural plans.
Happy to have a look if you email me at simeon@ashingtonhomes.com.au. Also can you explain why your builder thinks the plan is incorrect for context?
Thanks
Simeon
4
The solid line is just showing the step down. The section confirms that the porch slab was designed to be poured with the main house slab. This is usually a better…
15/08/2023
5
depends on your council, some 1 day some 14 days
4/09/2023
Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or…
