Do floor to ceiling tiles ad much resale value
If you can do the labour yourself it's well worth the extra little bit of tiles to go all the way up!
Just be sure that the cornice is installed after tiling and also that the walls are screwed or nailed of in accordance with AS3958.1
Particular attention should be paid to the following:
(a)The minimum recommended single layer plasterboard thickness to be 10 mm.
(b) Stud or furring centres to not exceed 600 mm.
(c) Gypsum plasterboard sheets used as a substrate for tiling to be fixed to the framing with nails or screws. Adhesive fixing is not acceptable.
- Sheets to be fixed at 150 mm centres on all framing members with 30 mm × 2.8 mm fibre-cement sheet nails
- no gyprock adhesive is installed to wet area sheets
6
Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling…
15/01/2024
3
As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is…
31/01/2024
2
The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy…
