Building a new place, curious if this truss is passable and ok?
Trusses
Probably nothing will happen even if you completely remove this truss there
lol at the moment yes. What about when a roof is placed on it
I wouldn't have to worry.
Shouldn't be a problem. If you are using Colorbond, your roof weights around 5 kg/m2. Roof trusses like that are generally designed to carry bigger loads and are oftentimes placed at 0.9 m intervals. In your case they are at 0.6 m?
Yep colourbond roof and 600 apart.
I do wonder when the frames go up and it’s seen why don’t they repair/replace it. I guess it isn’t an issue. Thanks
what is the worry? the knot?
Yes the knot that missing and split on the end. Turns out it needs rectification.
