Built-in wardrobe: MDF?
We're looking to build a built-in wardrobe ourselves. Is it a good idea to use MDF like this: https://www.youtube.com/watch?v=8dhWX7z_NfQ? The doors here are MDF as well. Is a proper frame needed?
Any advice appreciated.
If you can't find a local supplier, most cabinet shops will sell you full boards. They might even cut it for you at a reasonable price which would likely be cleaner cuts than you'd be able to manage yourself. If you cut yourself, ensure a nice clean and sharp blade. It's normally best to do a shallow scoring pass or otherwise ensure the good side is facing down so any tearout/chipping happen on the less critical side.
The edges of melamine really need to have banding as the particle board is quite porus.
Realistically, if you want a cabinet, and don't have the tools, add your time to the materials and just go buy a kit or flatpak.
So for me, I make a carcass out of melamine (from the green box) that I buy in sheets and rip down with a track saw, edge band and assemble using domino's, and use painted MRMDF for the doors which I buy at a Cabinet makers supply store.
That's the cheapest way for me, but I'm very fortunate to have the tools. Oh and time. ( id rather do this then an overtime shift)
3
Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the…
29/07/2023
We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some…
9/08/2023
1
Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry…
