How hard to change CDC plan for a brick veneer to double bri
I was wondering on how hard for architects/builders to change an existing CDC plan where the general building comments says brick veneer to a double brick build?
Its very simple to get a modification done, but you will need the structural plans updated and stamped as well
cheers
Simeon
cheers
Simeon
Thanks for the info, whats the usual turn-around for these processes?
cheers
Simeon
depends on your team. Mine does it in like a week
How about for the actual council/nsw portal? How long do they take if plans are all good to go?
depends on your council, some 1 day some 14 days
1
can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out
1/10/2023
1
Brass fly wire, you will need to cut it, shape it and jam it into brick slots
5/04/2024
3
fair question about the slope. Re soil I mean that it doesn't look like reactive clay which swells and shrinks with wetness/dryness. If the floors in your house are…
