Orange rust spots one driveway
I was wondering what exactly causes those orange rust spots to appear on someone's driveway and what can be done to prevent it?
Prevention? Ensure adequate concrete cover.
Remedy? None.
If so, it's most likely some ironstone aggregate.
It's a naturally occurring formation in some rocks and sometimes odd little bits end up in the mix.
The staining itself can be removed with an iron stain remover but it will come back. If it's exposed aggregate you can locate the stone in the surface and remove it, then clean the stain.
Here is an explanation and resource that describes how to deal with it.
https://www.google.com/url?sa=t&source= ... 5zKGyTOgrH
If it's incorrectly placed reinforcement then you will have major problems going forward but most of the time it's what I've noted above.
Most lawn foods contain some iron sulphates
Could also be as a result of fertilizer application, not sweeping granules off the concrete and those granules then getting wet.
This happened to mine. Some simple bleach fixed the stains
If the driveways isn't sealed and it has time to work it's way in it's there for good
Smaller suppliers get the lower quality raw materials
22
THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so…
8/01/2024
4
if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush
7/03/2024
2
That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel
