Brickwork - New Home
Wanted to know if the lack of interlocking bricks on where the garage door is to be placed could cause any issues?
The rest of the home the bricks are interlocked but not here and I was worried the bricks may split from the mortar if weight is pushing down on it.
Not knowing any better I thought it would be good to ask.
Thanks for any advice.
[img:35n7ni6d]https://forum.homeone.com.au/u/105949_1660531566.jpg[/img:35n7ni6d]
Shmaybe
Pity you didn't take photos during the brickwork stage
and checked them against the certified engineering notes.
There should be metal wall ties connecting brick leaves.
To be 100% certain the wall will need to be scanned
Scanning walls for cracks in wall above wall frame
Hey Pity you didn't take photos during the brickwork stage
Hey Shmaybe
Hi StructuralBIMGuy,
I don't have photos but I can confirm seeing the metal ties in that part of the wall. Was every 2nd brick from the ground level.
So the ties add a lot of strength to the wall?
Cheers for the assistance.
8
I am in the same situation, would you be able to give some insights in to this? I am in SA
