Hi guys, first time building a duplex with masterton. Now that I need to finalise external colours, it just occurred to me that perhaps the fascade is poorly designed and unattractive. What do you think? I don’t want to spend too much so if there is a way I can do fascade improvement at low cost, that would be greatly appreciated. Should I go surfmist (very light biege) garage door instead of monument? Note that I am using PGH Blackheath brick, all window frames are black and the front entrance door will be brown timber and not mahogany. Many thanks, you legends!
Is this an ugly fascade?
Hi guys, first time building a duplex with masterton. Now that I need to finalise external colours, it just occurred to me that perhaps the fascade is poorly designed and unattractive. What do you think? I don’t want to spend too much so if there is a way I can do fascade improvement at low cost, they would be greatly appreciated. Should I go surfmist (very light biege) garage door instead of monument? Note that I am using PGH Blackheath brick, all window frames are black and the front entrance door will be brown timber and not mahogany. Many thanks, you legends!
Morning Marwa
I would go the other way and change your columns to a monument and you mentioned the timber doors would be a lighter colour great.
In summary try and have as few colours as possible and stick with the black theme:
1. Roof Momument
2. Windows Black
3. Colums Momument/dark
4. Garage door Momument
5. Front door - light colour timber with black handle
just me 2 cents
Enjoy your build
Simeon
And yes, stick to a limited palate.
However, what bugs me is the asymmetry in the windows. Why has one side got two windows, where the other has one? That just looks off kilter.
Morning Marwa
1. Roof Momument
2. Windows Black
just me 2 cents
Enjoy your build
Simeon
Hi @ashington Homes with the above colour suggestion, what colour you would suggest for gutter fascia downpipes. thanks
Morning Marwa
1. Roof Momument
2. Windows Black
just me 2 cents
Enjoy your build
Simeon
I would keep it all consistent with the roof, so definitely monument
It's winking at you!
Yes, you have to be careful to avoid unintended consequences but the windows do match the current doors.
Life was fine before that damn movie!
2
at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with…
