I am building in WA and like the idea of insulating the cavity with blow in styrofoam balls but wont that cause an issue with the moisture level and weep holes if the air cavity is filled? ie how is the moisture going to escape? Or is there a better material?
Thanks
Double brick - Insulation and Weep holes
Thanks
They're pretty good with advice and open to questions about any concerns you might have.
InsulGuard Insulation - Home Comfort, Security & Sustainability Lives Here
P.S. I don't work for them
Weephole screens can be purchased from Bunnings in either aluminium or plastic
Give these guys a call.
Thanks Althom - I'll check them out
4
You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me.
13/06/2023
1
it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you…
27/07/2023
5
I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible
