Masterton Homes - The new thread 3.0
Page 40 of 152
No they don't remove their all weather access driveway. They will (if you nag) come and clean up the site of other building debris.
Hi Jo&Waz,
The stairs don't go in til later - they will then create the under stairs doorway and hidey hole
Cheers
Hi Paulevan,
Hi Jo&Waz,
The stairs don't go in til later - they will then create the under stairs doorway and hidey hole I think ours went in after gyprocking (I'll go back through my photos).
Cheers
Hi Jo&Waz,
Cheers
Just found out the construction 20 day countdown does not start till the survey pegs are done and M has the report from the surveyor.
DSA - Our back stacker door had a beam on an angle from the alfresco to the door open, once our stack door was installed it disappeared, so dont fear that its permanent, they use the offcuts of the timber used on the build for other purposes... There were lots of things we thought were not right, but once the next step was completed it all fell into place..
Hey Rinnai79 Im pretty sure this is permanent. The middle post isnt supposed to be there
This is an old photo the roof is up now and the other timbers that have been temporarily put in place of the brick pillars look nothing like this middle one
What do your plans show?
To everyone,make sure the painters undercoat your walls and ceiling before painting as ours wernt(short cuts) and thats why we now have to have it all sanded back and redone,what a pain its going to be now that we are living here,moving and covering the furniture let alone the mess its going to create.
Wow, they've stuffed up big-time then. There will have to be significant overhead support for that arrangement - I-beams or similar bolted together. You've got nothing there!
How do the doors join together on the plan?
Thanks guys
how can you tell?
nugget
You can normally tell with the finished product,as we can see through it in most spots as well as seeing where all the joins are in the gybrock,you can also request with your ss an inspection when the painters are in.With our painters they came in way too early and were working around other workers,mainly the tiler and they didnt cover anything so i had paint splatters all over my kitchen and bathrooms that took ages to get off.
I guess I'll be too hopeful to have roof before xmas break. Most likely just a slab.
I'm two minded here. Just not too keen on having bare frames up for 5 weeks, with rain and all. If roof will not make it before the break, I'll rather wait till after the break.
I've been told that sometimes M does not go on a long break during xmas. Anyone experience this?
Our slab was poured around 4.5 weeks ago now. The bricks are 2/3 of the way done and should be finished next week and the roof tiles/fascia and gutters should be done the following week. So all up from slab to roof & bricks complete for us was 7 weeks. Its now around 9.5 weeks to xmas.
I reckon you might just squeeze in having your bricks and roof tiles done.
M state they have a 5 week industry shut down but I think it will be up to the tradies as I cant see a lot of them taking 5 weeks off. They'd go broke.
For us, and going by other peoples timelines, we should be definitely at lock up stage in around 4-6 weeks and have a lot of the internal fit-out done before xmas. I dont think we will see the painting and flooring done until after xmas.
It wouldve been great if M installed the roof before the wrap.
This wouldve enabled the electrical rough in, insulation and gyp-rocking to get started along with the bricks. Weve lost about 2 weeks because of this error. Oh well....
how can you tell?
nugget
Vatche - Good stuff.
Ours is two story though, so it might take longer. As long as there is a roof, or short break, I'm fine with it.
BTW, my build timeline data collection is getting there. More work than I thought, due to variations if the build is KDR or vacant land etc.
Thanks to all the bloggers in advance for the info.
The xmas shutdown was 3 weeks,starting from xmas eve for us
That's good. Normal xmas time off, same time as we take time off work too. Hope it is 3 weeks for us too.
Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and…
10/03/2024
Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs…
