New Living Homes
Page 23 of 45
Our site supervisor is the same and if we do get a response it's a very short reply
Kind of hoped there would be better communication but our build is almost done so won't have to deal with them soon...disappointing though.
We get random updates but when we have actual questions, its silence. NLH definitely need to improve on this aspect of their service.
We have only received one call giving us an update the other times it's been is trying to get an update which can take forever to get a response.
Definitely something they need to work on cause other than this it's been a great experience with NLH...
Hopefully your not to far off completion!
We had our brickwork finished last week and the electricals were done yesterday. My own estimates put us somewhere towards the end of August/early September for completion but who knows at this point!
Our Site Supervisors are very busy out on the building sites doing inspections daily, if you have a concern about the communication you are receiving please call 1300 366 766. Our admin staff can often help and answer any questions you have as your build is thoroughly documented on our system. Any technical questions can be forwarded to our Construction Manager or Site Supervisors.
Thank you
New Living Homes Admin Team
If we are having our PCI walk through on Wednesday 29/07 and we find no faults how soon after that approximately would we be able to get the keys to the property?
Thanks
I need more understanding on the below points in your tender with NLH on site costs.
Sewerage Connections
Sewerage connection to existing junction of supply authority's main within the property Included boundary. Subject to Sewerage / Water Authorities requirements. Please note that there is no allowance for the extension to the sewerage mains outside the property boundary. - Do they cover extension in your tender? Does it really add to extras when after you sign the contract
Electrical Meter Connection
Provide up to 8 meters of single-phase underground service cable from the existing supply Included authority turret/pillar to the meter box. The meterbox is to be wired to suit a single phase meter.
Piering
Provide concrete piers to a depth of approximately 1 metre to the underside of the slab, to Included even bearing, as recommended by AS2870.
Salinity
Due to the site being in a salinity affected area the following is required;
Included
a) A salinity certificate.
b) 32Mpa concrete to the main ground slab and 300um high impact resistant plastic membrane in lieu of standard.
Note: Any retaining walls should be constructed of salinity resistant materials and the finished external ground, landscape, levels are to be below brickwork due to the affects of the salinity affected ground.
In Provision Allowances for Site Costs,
In accordance with the Building and Design Guidelines, by Jordan Springs, provide the $4,500
following site costs, as specified:
- Provide a 650mm deep dropped edge beam, due to zero boundary construction, in lieu of
standard.
- Provide fire-rated Rockwool insulation to the gutter/roof detail on the side elevation of the
Garage, in lieu of standard.
- Provide flashing to the zero boundary.
I would need the suggestion from this forum on the above points.
Has anyone built Maple 10 with New living Homes,
Cheers
For Maple 10, Does anyone know how much extra would be the cost to upgrade from standard porcelain tiles to a bigger porcelain tiles.
Also, I heard the standard carpets are not of good quality. Let me know if someone upgraded the carpets to better carpets or tiles.
Cheers,
AB
Has anyone made changes to Maple 10 from New Living homes? I do not like the layout of four bedrooms in a row. Any advice? How is Protea 4.1? It is good as per the floor plan but width is less.
Amit
I did some changes to Maple 10. We swapped media room with bedroom 4 and made the media room in same line with the kitchen. And Bed room 3 now have bigger BIW.
Thanks
First home buyer here. Has anyone built the azalea 4? How'd it go? Any feedback? It's on display at willowdale. We've decided on it. Just waiting for our land to register.
Hi guys.
Hi Steve_89
We are 1st home buyers too and building Azalea4. Currently at brick stage. So far no issues to complain about except for little slow progress. We have done some upgrades and hope it will look better than display house when finished
Hi guys.
Hi Steve_89,
My wife and i are looking at building the Azalea 4 as well. Where will you be building?
Hi guys.
Hi Steve_89,
Hi Dvs.
We are building at newbrook estate.
Land hasn't registered yet though.
Where are you building?
Hi guys.
Hi Steve_89,
Hi Dvs.
Oh nice.
Our land hasn't registered yet either, will be June 2016.
Land is at Jordan Springs.
Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs…
15/11/2023
Can anyone suggest a house layout where the kitchen-dining - living runs the length across the rear of the house left to right where our best view will be we…
