Hi,
Thanks for sharing your experience, it's great to be able to see the process happening and your feedback.
I am going to be building with Weeks soon and hope you don't mind me asking a couple of questions?
You did your flooring after handover is that correct?
Did you ask Weeks to pin your skirting boards so that the installer of your floors could take them off, put the flooring in and then put the skirting on properly?
Did you use quading / scotia around the edges of your flooring, e.g. with the kitchen island (personally I don't like scotia's), but was hoping there may be a way to have kitchen cupboards raised to allow the flooring to go under the edges of the cupboards later. Similarly with the kitchen island if that was able to be raised to suit the height of the flooring pre-chosen so that it could be accommodated at install time.
Also how did you go with your contract at signing stage, did you ask for any changes, or were you happy to sign as it was. Was your build completed on time?
Thank you, appreciate your feedback if possible
Hi Black Duck,
All the best with your build!
Yes, we did flooring post handover, we too were worried about the skirting boards not being done in conjunction with the flooring. We thought about Weeks just 'tacking' them on and then getting the flooring people to install them correctly but, like everything, this would have cost extra for the flooring people to do this. And in addition, we would have to paint the skirting boards too. We ended up just having Weeks install and paint as usual and have the flooring people put scotia on. Honestly does not worry us in the slightest, if anything it adds some nice detail. We matched the scotia with our flooring so your eye is not drawn to it
We didn't make any changes at signing stage, nor post signing stage. We made sure we had everything in order before this point (made a lot of changes prior to this point)
The stage from signing to build start was the longest and most frustrating. The admin is not good, unless you ask for an update, or when something will be done, things don't seem to happen. The selections process was quite good and helpful
Once the actual build commenced, everything went quite smoothly and in a timely manner. We had a great Site Supervisor in Andrew which made all the difference
We are loving our home and cant fault the build quality
